Skydemon won't connect to Safesky with "Address Already In Use" message
Using an iPad mini, Skyecho 2, Safesky and Skydemon. After connecting Safesky to the Skyecho Wifi and minimizing, when I select ‘Go Flying’ and GLD 90 device on Skydemon I get the error message “Address Already in Use”. I have tried every possible start up sequence and tried multiple iPad settings. Very occasionally it will work but when I shut down and restart I am back in the same loop.. Also ccasionally the Wifi link to Skyecho drops despite being on the ground. Things work if I use ‘location services’ for Safesky instead of Skyecho. I am trialing premium membership but this seems way to unreliable to risk flying with.
Hello Andrew,
We are trying to reproduce on our side the problem you described. It’s possible to be a local configuration issue, we will come back to you shortly.
Hey, me too, I have the same issues
Hi Tristan - is there any update on this topic. Everything seems to work when I connect Safesky to Location Services on the iPad mini and traffic shows on Skydemon. If I try to use the Skyecho 2 I always get the “Address Already in Use” message.
Same problem here. The “Address already in use” message usually appears in SkyDemon after the first SafeSky “Take Off” after connecting to the SkyEcho 2.
I then have to stop SafeSky and tap “Take Off” again. After that, SkyDemon can connect without any problems.
Skydemon 4.3.2.453, Safesky 3.0.34, iPad mini (5th generation). iPad OS 26.5.2
I can confirm DavidFlint message. Seeing this exact same issue ob iPad Mini 7 (IOS 26.6.1), SkyDemon (version 4.3.2) and SafeSky (version 3.0.35) with my SkyEcho II.
Dear SafeSky Support Team,
I am experiencing the same problem when trying to use SafeSky together with SkyDemon and a SkyEcho 2 on the same iPad.
My intended setup is:
SkyEcho 2 → SafeSky → SkyDemon
However, when I start SkyDemon and select “Go Flying → Use GDL90 Compatible Device”, SkyDemon reports:
“Not connected. Address already in use.”
I have carried out the following troubleshooting steps:
  1. Tested SkyEcho 2 directly with SkyDemon, without SafeSky running. This works correctly.
  2. Completely closed both SafeSky and SkyDemon and restarted them in the recommended order:
    • Connected the iPad to the SkyEcho Wi-Fi
    • Started SafeSky
    • Enabled Traffic Sharing and selected SkyDemon
    • Enabled External Traffic Device and selected SkyEcho
    • Started the flight in SafeSky using “TAKE OFF”
    • Put SafeSky into the background
    • Started SkyDemon and selected “Use GDL90 Compatible Device”
    This results in the “Address already in use” error.
Could you please advise whether this is a known issue with SafeSky/SkyDemon on iPadOS, or whether there is a setting or workaround required to prevent the apparent GDL90/UDP socket conflict?
Thank you very much for your support.
Kind regards,
FrequentFlyer
