Hello, did you have chat with Tristan about your router 4G ?
Did you completed more tests?
Thanks , please come back to me (in FR or EN)
Hi Christophe,
No I never heard from him.
I wanted to propose a test comparing data transfers using the on board wifi vs using a mobile in flight.
Perhaps you could ask him to contact me.
Thanks,
Clive.
Hi Clive!
Christophe did some comparable tests. Can you have a look at it? Thanks! https://www.safesky.app/en/post/a-4g-router-in-my-aircraft
Very interesting. I believe the aircraft used is of composite construction.
I think the improvement will be more significant in and all metal aircraft.
I do still intend to make some tests in my Savannah. At the moment a combination of work and weather is getting in the way of doing that.
My idea is to have a mobile in a phone holder creating one hotspot, and the 4G router with it’s own wifi hotspot. I will then run a script on my notepad pc to connect to one hotspot, send and receive some data then switch to the other hotspot and do the same, then repeat. It looks like I can compare each connection approx. every 30 seconds.
That would be great, Clive!
Christophe is creating a special WhatsApp group for those pilots wanting to test these routers and antennas. If you are interested, drop him a line : christophe @ safesky.app
