I connect my iPhone and my iPad to the SE WiFi, then “Take-Off” in SS, then “Go Flying” in SD on both the iPhone and iPad and, for a time, it all works, but I then get this:
I had a similar behavior but in my case also lost connection to SD.
The SE guys told me that the latest SE2 wifi firmware got limited Wifi transmission power due to some nasty regulations resulting in frequent connection losses.
I reverted back the SE2 Wifi firmware to version 0.2.35 what resolved the issue on my end.
Maybe worth a try?
Hi all, I got an answer on this, has to do a bit with SkyDemon. Basically, the idea was to NOT select SkyEcho in SkyDemon, but the GDL90 compliant device. Same for SkyEcho. Hope that helps.
