SafeSky geeft geen verkeer meer op scherm .
I pad all opnieuw opgestart krijg niet werkend
Hi @PH-ZEE
Could you please check those points:
- Last version (not the reason, but always better)
- Be sure that the iPAD use a SIM card or is connectez to a WIFI giving Access to Internet.
- See settings in the iPad for the App SafeSky⌠(see screenshot)
It should work, thereâs no reason for itâŚ
Please confirm that everything is in order.
Thanks for your answers
Checked all points No result
Abel to buy new I pad ![]()
Safesky works on iPhone good
Hear warning from planes but donât see them. Get to see on map again.
Getint Weather on the map and warning from planes
But not visuwel on screen
I wil try my Ipad, (needs to charge
come back if itâs running
The last photo shows that the internet works
Hello @Sunrader
I suggest you reset your filter setting (top right menu from the filter box), as it seems that most traffic types and transponders are unselected (blue badge icons).
I suspect this should fix your issue?
Hello @PH-ZEE ,
We are investigating on your case, we suspect a local IOS setting going wrong.
Could you please send a screenshot of your SafeSky configuration from IOS, similar to the one above?
I also see you are connected over Wifi, is it possible to try with LTE network in case you have a SIM iPad?
Thanks,
geprobeerd op mobiel data werkt ook niet
I have fly traffic on screen again erased and reinstalled I pad
Hallo Safesky users
Sinds Versie 3.0.8 krijg ik geen verkeer meer te zien op Android OnePlus11 OxygenOS 14.0.
Safesky heeft locatietoegang, app al een keer un-installed en opnieuw geinstalleerd, filters geresetâŚ
Straffe is dat âLive.safesky.app/mapâ (ook in desktopmode op GSM) ook geen verkeer weergeeft.
V3.0.8 werkt hier wel goed op Lenovo Tablet Android V10
Safeskies
Dirk claesen
OO-E06 CT2K
PS: Thx voor de fijne babbel op AERO24!
Indien skydemon de gdl90 data overneemt dan geeft skydemon wel de Trafic in beeldâŚ
