Flightradar24 vs safesky
I’m wondering why some VFR civilian flights can be displayed on flightradar24 and the same are not seen by safesky.
Any idea ?
Í asked flightradar24 while ago about this.
The reason for this is the transmission power is low from SkyEcho ( 20 watts I think) which means that flightradar24 does not detect the signal easly but do some times partially.
Flightradar24 say that to be detectet requiers much higher power output from transponders and " real " transponder have about 50 to 100 watts output😉
Hi Von,
Can you provide screenshots and/or info on aircraft visible on FR24 but not on SafeSky?
Maybe you did not have a good mobile data connection at the time?
Tony
This post of mine above should be deleted. Wrong place submitted
