Guys,
do You also have problems with iPad overheating while flying with SkyDemon and SafeSky connected together.
I had this problem on older iPad Mini 4, changed to latest Mini 7 recently.
Now while sun is out again even in Norway, I can again feel the heat and experience the whole system slow down due to overheating.
When I run SkyDemon alone, it’s normal.
SafeSky - more heat than normal.
Both - then the overheating starts.
I’m worried that when in southern Europe in summer - that solution might be totally unusable.
