I want to install SafeSky on Xiaomi Pad 7 under Android 15. Google Play says: App does not run on your device. Is there a solution for this problem?
Bonjour, j’ai le même problème avec une tablette sous Android 15. Je suis Également à la recherche d’ une solution .
The android version should not be the problem. According to the AppStore details, it requires Android 7 or higher. Maybe you tablet has no GPS and that is blocking the install? Newer tablets with Wifi-only typically don’t have GPS.
You could always try to download the APK and install the app manually. But you have to be careful to get the file from a trustworthy source…
