I used safesky and Skydemon. In the safesky app it looked like i was flying formation with myself. There were constant approx warnings for flying very close to another aircraft (myself). What did i do wrong?
Hi Olle,
had the same issue sole time ago.
In case you have cobnfigured multiple airplanes in Safesky check that you selected the right one
Then you have to check if your Hex Code of the Transponder is set correctly in Safesky (and may be also in Skydemon). Then it should work.
WILCO, thanks!
Please, take a look on the user manual.
This is clearly explained.
Fly safe.
