Help needed with Setup PowerFlarm Portable with Wifi + Skydemon
Dear community,
I am using the following setup:
GTX330 Mode S with no ADS-B out
iPad (Wifi + 5G) with Skydemon
PowerFlarm Portable with Air Connect Wifi Module
Question: How do I need to set up my Combo in order to receive both Online Traffic on Skydemon by Safesky AND PowerFlarm-Traffic?
I only get it to work one at a time. When I connect my Skydemon to the Flarm I don’t get Safesky data. If I connect Skydemon with GDL 90, I receive Safesky data but no FLARM and Safesky sais it can’t connect to FLARM: “Waiting for Flarm”. (Safesky AND Flarm use the correct HEX Code of my Mode S XPDR).
I tried to use GDL90 on my Skydemon while trying to Connect my iPad with the FLARM´s Wifi. But either I will then have no more internet connection or Safesky will say “waiting for Flarm” and can’t connect to it.
Thank you! Kind regards, safe flights,
Pat
Please take a look on the manual.
Setup is similar to the SKYECHO2
Ty. It just doesn’t work, I get this message:
Could t connect to Flarm.
While Skydemon gets Flarm Data and IS connected.
Regards,
Patrick
Same problem with my set.
My VFRnav works perfect with my powerflarm portable Wifi-AP (192.168.1.1:2000)
My VFRnav works perfect with my safesky at UDP:4000
My safesky doesn’t find my powerflarm portable at my wifi-ap,
even if I handle my ip-adress manually!!!?
The manual couldn’t help me either.
Regards
