Freeing up space on my device
Dear SafeSky team,
I’ve been checking the apps and free space on my phone recently and found out that SafeSky takes a lot of disc space (7.83 GB). Is there any way to free up some of that space, probably by deleting old logs?
There is an option to delete all files in the app setting directly on my phone, however I’m afraid to do so, because it also says that this will delete all information, including account details and saved login data.
Is there any way to clear up some space in the SafeSky?
Thank you,
Peter
Hi @ULpilot ,
Yes, you can safely use your phone’s storage settings to delete SafeSky data. You’ll just need to log back in afterward.
SafeSky stores your flight logs locally on your device. The app also has a built-in option to delete individual flight logs: go to Menu → Flight Reports, tap on any flight, and you’ll see a delete option. This lets you keep recent flights while removing old ones.
If you’re a SafeSky Premium user, your flights are also backed up in the cloud, so they won’t be lost even if you clear the app’s local storage.
Best regards
Hi Vincent,
Appreciate your quick reply. It worked.
Thanks,
Peter
