A little change request regarding map-center Button
Sometimes I do more like to fly with the map-Mode instead of the radar mode.
I zoom in quite a lot to see the planes in my proximity.
But then the map is not moving, my planes continues and flys out of my map view.
When I press on the map-center button, it recenters my plane, but also it zoomes out a lot!
Thats quite annoying, I would recomment only to center and not to change the zoom-level.
And it would be great, when then the map is moving and the plane stays in the center.
Thank you for your message,
We are currently working on a new version where the map and the radar will be revised.
The map has already been discussed with us and should be adapted.
Stay tuned for further information via our newsletter. If you haven’t registered yet, you can do so directly via the SafeSky application or on our website.
Best regards
Hey,
For some reason i will come back to this topic.
I still would like to have a change, that a press on the recenter button in that overview screen (like mentioned above) should only center my aircraft and track my aircraft in the middle of the screen.
But there should NO CHANGE in zoom factor happen!!
And it also would be nice, that MY aircraft also gets a flightpath vector, like the other aircraft have!
Hello @Breenild ,
Thanks for resurrecting this one :slight_smile:
I agree with you, we are adding your change request to our backlog about the zoom on the map and own vector.
Stay tuned, and Fly Safe,
Thank you very much that would be great!
