UAV realtime position
I just purchased the SafeSky Early Bird (Android app), and I am very impressed with the design of the application, the UI etc is very nicely done!
As I am primarly intending to use it with UAV flights (DJI drone) I was wondering if it would be possible to inject the real-time drone position into the app, so it would be dynamically updated? Could this type of functionality be offered via the API?
Many thanks for great work,
Andreas
Following +1
Educated guess here… you can use a ESP32 with OGN here. Very light weight! Since safesky as I understand will use the same networks your drone will be visible to other users of the sky.
There is also SoftRF you can look into…
The only solution I know is to buy a small android device f.ex.
Unihertz Jelly Pro, The Smallest 4G Smartphone in The World, Android 8.1 Oreo Unlocked Smart Phone with 2GB RAM and 16GB ROM, Sky Blue https://www.amazon.com/dp/B075276XNQ/ref=cm_sw_r_apan_glt_i_WT14S8SWNSR3P7CNWZA1
Then,
download and run SafeSky then tape/glue it to the drone and transmitt it’s position via the cellular network.
Not an ideal solution… :stuck_out_tongue_winking_eye:
Any news regarding this?
Is it possible to pull coordinates out from the DJI app and broadcast the position on Safesky via the app on same device?
I am not a programmer but the SDK is available here it seems…
https://developer.dji.com/
If so, This would be a game changer without doubt!
Hello Jonas,
I have been investigating this, and created a test app for Android that was able to show the dji data in realtime on SafeSky.
It requires that both apps are running, and that safesky can run in the background transmitting gps position data. The gps data is generated by the custom Android app using the dji sdk.
I hope to be able to do some more tests with this soon, and make a test version available.
/Andreas
This is exactly what I have been looking for! Any developments here?
It could be a game-changer for the industry if position sharing from the DJI app to Safesky was made easy.
I have an initial test version of Android DJI client app, that reports position to SafeSky by using of controlling the device GPS temporarily (mock location). Any testing of this version is welcome.
I am also looking into using other protocols to relay the position info to Safesky from DJI drones.
Regards,
Andreas
Hello
Your project is very interesting. I can see that there was no activity here the last year, so I am curious if it is still on-going, and if you made any progress?
/EHU
Hello!
The project is still alive, I have done tests with an Android app that sends realtime position from DJI drone to SafeSky using gdl90 (both apps run on same device, Safesky in background). It seems that you need to select takeoff in The Safesky app for the gdl90 data to be received, but I have got the uav position and altitude info to appear on Safesky map.
It should be possible to send this data to other Safesky users.
Is the project open for testing, and is the app published somewhere?
I will try to make a first test version available soon, if you provide an email I can sen you more info.
/Andreas
Den mån 13 maj 2024 00:37EHU via Safesky <notifications@safesky.discoursemail.com> skrev:
Hello. Any news?
I would like to have my DJI Air 3S live position brodcasted to Safesky.
Could you send me a email with more info?
