SafeSky stops in the backgroung of VFRNav
I use SafeSky premium connected to VFRNav via GDL90. Initially that works, but after a few minutes all the traffic disappears from VFRNav, and when I change to SafeSky, it has stopped an I have to restart the flight.
I use a google Pixel6 with Graphene OS, but I doubt this is the source of the problem…
Any suggestions?
Thanks!
Are you aware of the specific settings you need to adopt with Android?
The behaviour of this OS also depends very much on the device used.
I therefore invite you to take a look at our manual and check the settings for your OS.
This behaviour, of course, is not normal, and is probably linked to your internal operating system settings.
https://docs.safesky.app/books/safesky-pilot-playbook/chapter/5-technical-support-and-faqs
