Hi all,
If there are multiple aircraft (including the HEX code) configured in SafeSky, when connecting to the SkyEcho2 (not the GDL90), can it set the aircraft in SkyEcho?
E.g. if the previous aircraft was set to ABC-123 and now I am flying EFG-456, and if I select that from SafeSky, and connect to SkyEcho, will it set the right aircraft in the configuration?
Thanks for your help. ![]()
