SafeSky, PilotAware & FlyData.io
I have recently changed my aircraft. It has Dynon SkyView with ADS-B in/out. However, there is no FLARM (important as there are loads of gliders near when I am based).
So that I can see gliders electronically, I have purchased a PilotAware Rosetta and am successfully using that with the SafeSky app.
However, I don’t get any PilotAware traffic on FlyData.io. When on the ground and low altitude where I have a mobile signal, I see the SafeSky app tracks on FlyData.io.
Once I lose mobile signal, I see no PilotAware tracks on FlyData.io, yet I do see PilotAware tracks on the app.
Why does SafeSky not send PilotAware tracks it receives over Wifi from the PilotAware to FlyData.io over BLE so that the FlyData.io display mirrors the app?
Thanks :slight_smile:
Hi
I am Artur one of the developers of FLYsky Display.
SafeSky app is supposed to “transmit” that information to the Display, not sure if any of the filtering the app performs it’s affecting this, in regular circumstances what is shown on the “radar” view of the APP should also appear on the Display.
The Display itself has some filtering options that could eventually affect this. The main one would be Vertical Declutering (relative altitude of the target) and maybe Show Grounded Aircraft option. Since these are “gliders” could be possible that the reported ground speed is 0kmh and the Display would ignore those targets.
Unfortunately, don’t have hardware to test that exact combination, will try to replicate that situation with a SkyEcho 2 device (it’s in use by another person, only by the end of the week), I think I have checked this scenario with the SkyEcho but will confirm it again.
One possible workaround solution could be to have the Display connected to the Wifi network created by Rosetta, and enabling on the display support to receive Only GDL90 data via Wifi. The Display will attempt to merge the data from Rosetta and eventually SafeSky App to show information on the screen. (This merge had an issue before version 1.0.8.1, the latest version update 1.0.9.0should have that fixed).
On Rosetta it may be necessary to configure Rosetta to output data via WIFI in GDL90 format, check on the configuration Device Connect Setting https://www.pilotaware.com/knowledgebase/configuration and Choose All since I assume that PilotAware (UDP). option is probably required for SafeSky App Integration.
Thank You
Hi I managed to get it working…I joined the FLYsky display to the pilotaware wifi. I needed to configure the PilotAware to send “All” traffic over the net, not just GDL90 for some reason.
Once I did that and set the FLYsky to “Other” and FLYsky Wifi protocol to GDL90 it all started working with the PIlotAware data received direct by FLYsky, without having SafeSky open.
Once SafeSky is also open I hope to get SafeSky and PilotAware traffic on the FLYsky box, I couldn’t test as there were no aircraft nearby on SafeSky that were not on PilotAware.
So all good :slight_smile: Will report back to close this off once I’ve flown and tested that FLYdata can receive SafeSky and PilotWare data simultaneously.
