PowerFLARM Fusion - Safesky - Skydemon
I’ve just installed a PowerFLARM Fusion. I’m upgrading from the SE2, which worked pretty well. Safesky sees the traffic from the Fusion, but I can’t get it to send to Skydemon or for Skydemon to see the Safesky traffic. This works with the SE2. I don’t want to use “split screen” mode, I want the targets on my Skydemon display.
Is there a trick to making this work? Thanks!
What display device are you using? Android or Apple IOS?
Also, have you selected the correct data source in SkyDemon?
The SE2 connects via WIFI. The Safesky connection will be GDL90 and you can only select one source..
Hi - I’m using an ipad. Both Safesky and Skydemon are running on the same ipad. In SD I chose GDL90. At home, with just the ipad, I can get the SD to connect to Safesky. I’ll check next time I’m in the hangar to see if I can get it working. When going to “fly” mode in the Safesky, I see “location services” and “FLARM” - I didn’t see this before. Perhaps I need to take more time and do a few more reboots.
