Ownship warning with ModeS and Flarm System
Hi
I have ModeS Transponder and a Flarm Triadis TR-DVS.
During flight I receive several warnings from my own aircraft.
How can I enter my XPNDR hex code and my flarm ID?
Many thanks for your help.
You should find the answer here:
Tell us if it helped you!
Like yourself I have both ADSB and FLARM in/out. My transponder Hex code and FLARM code are the same. If you go in and edit your aircraft you can set the HEX code. I’ve attached a picture of the setup page you are looking for.
