Not having good reception
I have a Trinidad. Just started using SafeSky, but at 2000 feet around South East UK, the internet connection and therefore SafeSky is unreliable. I’ve tried the iPhone (11, O2) is different viewable positions, but no good.
Any ideas ?
Out of interest, how did you determine that the “internet connection” was unreliable?
I use an Android Samsung S22+ smartphone attached to my instrument panel and seem to get good (or adequate) mobile data connection. The SkySafe flight log showed something like 90% for a recent flight…
Hi, because it kept going offline. Maybe it’s just the area around London that has an issue.
If you can, try mounting/attaching your phone to your instrument panel so the top half has a clear view forward and upwards for best communication with the mobile phone network. Did you look at the flight log? It will tell you how good the SafeSky comms was during your flight.
Yes, the flight log looks complete from yesterday. I will try to mount it higher as you said.
I’ll report back to you after my next flight.
Thanks, Keith
Mine is mounted like this:
Thanks. I wonder if I’m losing signal because of the changing masts frequently due to speed. I was flying at 140kts yesterday- I see you are 95kts ?
85 MPH TAS!!!
I doubt that would be the issue, but may be.
I generally fly at 1700-2000 ft but I haven’t been aware of any mobile phone issues for me.
That said, I have only tried a few flights with SafeSky as I was primarily a SkyEcho 2 user.
Unfortunately, I can’t use Skydemon, SafeSky and my SE2 at the same time due to my Android phone.
Hopefully they will fix the Android issue…
What were you looking at to determine loss of mobile phone signal? SafeSky status or something else?
SafeSky status. It went offline just when it was warning me of close aircraft.
So not using SkyDemon, or split screen with both displayed? (SD and SS)?
No not yet. Just started using SafeSky
