SkyDemon freezes when connected to SafeSky
I’ve been using SS for several weeks and it’s a great app, however, when connected to Skydemon via GDL90, Skydemon on some occassions freezes and doesn’t responde at all. I need to restart Skydemon sometimes even 3 times. Then it starts working without any problems. Other times it works flawlessly from beginning. I’ve tried it on 3 different devices with the same outcome. It works just fine in a split screen mode. The problem is only when Skydemon uses GDL90 compatible device setting.
Do you have any idea what might cause this behaviour?
Thank you,
Peter
Thanks for your message.
Our dev team will help you, but before we need to know what devices are you using?
Thanks to transmit us those informations.
Thank you for your reply. We use a tablet Lenovo TAB M8 Full HD 3+32 GB Platinum Grey with Android 9.0 Pie and external wifi (hotspot from a mobile phone). SafeSky and Skydemon are on the same device. Another combination is a mobile phone Redmi Note 11 Pro 5G with Android 11. Again both SafeSky and Skydemon are on the same device, but now we use data directly from the phone and no external wifi.
