I have a “SafeSky equipped” something (OE-DTB) in the area of my Homebase that is present 24/7 but effectively never moves. It is only shown with SafeSky. In any other web based tracking program it’s not there. What could be done to get rid of such phantom planes?
I assume at this place is not even an aircraft, just a permanently switched-on mobile phone or terminal. Unfortunately, this phantom is in the approach sector of LOAV for months now.
Same happens with many paragliders. You can perfectly monitor them long after sunset when they drive home along the road
Unfotunately, such unreal aircrafts lead to false alarms and disrupt the system. More discipline is needed here.
Meanwhile an increasing number of ground stations and others are broadcasting live traffic. Unfortunately, this leads to a certain multiplication. Example see below.
OE-BXR and OEBXR are the same aircraft and not two helicoptes moving around side by side.
I recently noted that my own plane has been shown twice. Once based on the installed ADSB and once as FLARM (which is definitely not installed). The false FLARM caused a permanent traffic alarm.
An intelligent filtering of obviously doubled aircrafts is required.
the screenshot with the two helicopters (OE-BXR) has been taken 14.Nov.2024 at 14:46, that one with the planes (D-KDRZ) on 15.Nov.2024 at 15:11.
All in the area of LOAV.
