Good morning. Sometimes (not always) the plane I am flying is displayed twice. Resulting in a warning of a nearby plane.
I suspect that your aircraft has a Mode S transponder and SafeSky is detecting it via MLAT. Something likely not set up correctly in your SafeSky configuration?
Tony
Perhaps you can connect your device to SaveSky. A had the samen problem with a invisible plane coming after me and making the same turn as i was going.
Like what the others say.. if you have a flarm device it could also be that it was setup using the incorrect ICAO code.
Left or right, no all your devices, including safe sky share the correct ICAO code. If they are different, then you might see doubles..
note: it does however look like a MLAT device because of the lag… expect MLAT at least one or a few seconds behind the real triffic.
