Hello!
Before buying, I tried to reach out to sales to better understand the Aero Tracker. Unfortunately, I never received a reply, so any help answering the questions below is much appreciated:
-Why does the device need internet connection if the phone or tablet that I am using to display the radio traffic already capable of streaming the internet traffic?
-In case it absolutely needs internet connection: Can it be used with a mobile hotspot instead of an internal SIM-card?
-Can it be set to receive only (disable transmitting radio traffic) to serve as a ground station?
I have been testing the Aero Tracker, as a GA pilot, so can answer some of your questions.
The Tracker’s built-in LTE data connection capability is superior to a regular mobile data connection. SafeSky will have to tell you more about the benefits but is something to do with being more efficient and quicker with regards to transfer of data (other aircraft positions in your vicinity (MLAT and OGN data etc.)) and the ability to seamlessly switch between mobile operators when flying.
I believe the Aero Tracker’s LTE data connection will only work with its built in sim card.
Regarding using the Aero Tracker as a ground station, I think you need to contact SafeSky about this so they can understand what you are trying to achieve.
FYI, the Aero Tracker only transmits data via its ADS-L and LTE capability.
However, if the Aero Tracker isn’t moving the LTE data service stops after 10 minutes in order to minimise data transfer over LTE.
As soon as you move (as in flying), data transmission over LTE starts again.
In addition to this, the built-in SIM card comes with roaming enabled, allowing it to automatically select the best available network, even within your own country, to maximise LTE reception during flight.
The Aero-Tracker is designed as a true Plug & Fly solution, meaning you cannot use your own SIM card or hook on your phone as a mobile hotspot.
Unfortunately, Garmin continues to keep its interfaces closed to third-party integrations. Even the widely adopted GDL90 protocol, which they originally created, is currently not supported.
We are in contact with them to discuss potential solutions and will share updates if any progress is made.
Hi there, I am using Aerotracker with flarm enabled and I am generally very satisfied. I have noticed that when Flarm targets are received over air and over internet I get double targets. Generally not a problem but it overloads the screen. Any solution to that? The Hex codes of the received aircraft are set similar on it’s farm and transponder.
